Questions regarding Handlebar Combo Mount vs TT Combo Mount
shafiqeffendy
Post by shafiqeffendy »
Good day,
I've tried searching in the forum, but I couldn't find any related threads about the question that I wanted to ask.
I currently have the PP, mounted on a normal Handlebar. I plan to install Clip On Aerobars very soon, and I will probably be on the Aerobar 30% of the time, and on the hoods 70%.
In order to have a neat setup, I plan to purchase either the Handlebar Combo Mount, or the TT Combo Mount. My questions:
a) Which one would be a better solution? Handlebar or TT Combo Mount?
b) Will PP recognize the change of my positions and compensate for the appropriate Cd (between on the Aerobar and the hoods)?
c) Do i need to setup different profiles, for different positions in PP? (For instance, Profile 1 if I use Aerobars during a TT event, Profile 2 for normal Group rides)?
If there is anyone out there having a similar setup, please share your thoughts and ideas too!
Re: Questions regarding Handlebar Combo Mount vs TT Combo Mo
I would use the handlebar combo mount. You'll be able to attach and remove your TT bars without changing your basic bike setup.
You should create two profiles: one for your road bike position, one for your TT bike position.
You will need to manually switch profiles, depending on which configuration you're riding each day.
