Profile number 2 question
andrewkerr1991
Post by andrewkerr1991 »
I am a little confused as have read a few different things regarding the Profile setups.
I have seen that your only meant to use profile 2 if using a combo mount with Go pro out in front. However i have setup a profile 2 using the PP mounted on the handlebar, as i have only just noticed this. Under the device setup on Isaac you can select the position of where the PP is located. My question is what effect will this be having with the PP numbers ? do i need to delete the setup and re-calibrate the PP ?
sorry for all the questions, i cant seem to find any answers so hence the need to ask.
thanks again
Andrew
Re: Profile number 2 question
If you use the Out and Back calibration, you can select any profile you wish (including profile 2).
andrewkerr1991
Thanks for fast response John.
Much appreciated.
