PP ride files showing much lower air temp than actual
flahutewannabe
Post by flahutewannabe »
Curious about my ride files showing approx 10-15 degrees F lower than actual. Is there a setting somewhere to adjust that? For example, my last ride is showing 35F; actual temps during the ride ranged from 50-53F. Previous ride showed 52F; actual were 70-72F.
Looking back, all rides so far are showing 1014 mb pressure; not sure if that's appropriate or not.
Re: PP ride files showing much lower air temp than actual
Temperature readings are approximate, and have no effect on power measurements.
There is no place to adjust temperature.
ronpei
Post by ronpei »
just a thought John, why could you not put it as a n option in the analyze route page? You could enter starting temperature, after that all that is needed is a simple temperature off set, ie if the actual starting temp was 25 deg C and the temp recorded by the newton or PP said 21 then all temperatures could be adjusted by an off set of 4? I have no problem believing that the temp sensor is correct when it stabilizes or is relatively correct in that if the temp changes 1 deg the PP sees that correctly. IT just continuously reads the wrong initial temperature even after stabilizing to the ambient. My Newton+ has always read a few degrees off and as someone noted it would be nice to see correct temperatures just like adjusting for starting elevation.
