My third roadbike and my race bikes both have outfront combo K-edge mounts, so will I need an additional profile for this mounting option? I have two PP's (red and black, of course) and two magnetless speed sensors, so I have the option of additional profiles for each PP, although the red is on a dedicated TT bike and I'm reluctant to move it (I use a bolt rather than the supplied thumb-bolt and access is not easy under the aerobars), I can remove it's speed sensor, pair this with the black PP and mount to the oufront race bikes. Please advise?
One final thought, I had little joy with the original combo cadence/speed Garmin sensor (although it did give me the highest readings I've ever seen thanks to being faulty), nor the Giant integrated ones, but the front hub mounted magnet-less speed sensors have been utterly flawless. Have you considered adding them to the package by default, since a lot of initial set-up errors seem to come from the initial speed sensor pairing? Perhaps you can do a deal with Garmin
Kind regards,
daren
