first of all, PowerPod is a great device!
So hopefully you can help me to understand/correct my data.
1. I received the PowerPod on february, so my first question is why is there a file from 01_10_2017?
For the rides in feb. i did a calibration ride -it was very short, but seems to me ok. Unfortunately my weight und
the wheel dimensions were not correct -it should be 700x23c and weight 79 + 9 Kg.
2. After each correction the watt in all rides decreases -correct?
3. New calibration done today, 03_10_2017. High Peak in there-1200w?? correct?
4. How can i calibrate the feb. rides (e.g. 02_26) with this new data?
Many thanks in advance.
BR
Detlef
New calibration -how to..
- iBike_02_26_2017_1313_26_km_HiDef.ibr
- (656.99 KiB) Downloaded 247 times
- iBike_03_10_2017_1405_2_km_HiDef.ibr
- (27.38 KiB) Downloaded 206 times
- iBike_03_10_2017_1352_6_km_CalRide.ibr
- (123.18 KiB) Downloaded 203 times
Re: New calibration -how to..
1. Until you connect PP to Isaac, the clock inside it is set to an earlier date. Once you connect Isaac, the PP internal clock is updated
2. If your unit is properly calibrated, you should not correct watts after the ride. Your unit appears to be properly calibrated.
3. The purpose of the calibration is to make adjustments to the wind and tilt sensors. The watts numbers are not necessarily correct during the calibration
4. There is only a minor difference in calibration between your 2/26 and 3/10 ride. I would not mess with your older rides.
Great.. How it should be.
Will recommend folks to buy this great device.
BR
Detlef
BR
Detlef
Thank you! We very much appreciate the support of all our PowerPod customers. You folks are our best advocates
