Why does my power reading drop to zero while pedalling?
Ken
Post by Ken »
When riding the power reading often drops out even when pedaling up a moderate inline. Is there
A fault somewhere or a problem with my set up? I have had the PowerPoint about 2 weeks and despite resetting it numerous times the problem persists
Re: Why does my power reading drop to zero while pedalling?
It could be one of several things.
Please use Isaac software to download one of your .ibr ride files, then post the file here. We will take a look.
Ken
Post by Ken »
Thanks John,
I have uploaded 2 .ibr files (I hope)
I am finding that the readings fluctuate wildly now and the power reading is still
dropping out regularly.
I have the powepod paired to
Garmin 510 with speed and cadence sensor.
Hopefully we can get it working consistently
iBike_08_18_2016_0909_51_km.ibr
.ibr file
(426.29 KiB) Downloaded 248 times
iBike_11_26_2016_0559_36_km.ibr
ibr file
(365.61 KiB) Downloaded 267 times
It looks like you're using a Garmin GSC-10, or perhaps Giant RideSense sensor. Both are "weak" transmitters and cause dropouts.
Neither works well with PP. I suggest you get a magnet-less speed and cadence sensor from Garmin or Wahoo.
Ken
Post by Ken »
I have it paired with
A Garmin Edge 510 and the matching Garmin speed/ Cadence sensor. Does that alter your answer?
The Garmin GSC-10 is not a very good sensor. It is the cause of your dropouts.
Ken
Post by Ken »
Thanks John ,
Will give it a try and report back
Let us know what you find!
