Need for "Check Calibration"?
Fabpod
Post by Fabpod »
Hi, After a couple of rides, the Powerpod seems to behave as expected except that ibike is showing only head winds on the graphs with NP in a 150-175 range. I wonder if I need to proceed with a "check calibration", which would increase the power stats. Could you please advise?
Also, since I spent most of time cycling around a 3.5km track, I would like to know if it makes sense to only select a few "clean" loops ("keep selection" in ibike) before doing the "check calibration".
Below the statistics and the GPS tracks on Garmin Connect:
https://connect.garmin.com/modern/activity/1257800601
https://connect.garmin.com/modern/activity/1259478093
I have also uploaded the ibr files.
Thanks in advance for your assistance
Regards
Fabien
iBike_07_17_2016_0924_42_km.ibr
(252.94 KiB) Downloaded 261 times
iBike_07_16_2016_0904_37_km.ibr
(225.48 KiB) Downloaded 222 times
Re: Need for "Check Calibration"?
I adjusted your profile so that wind speed would be similar to bike speed.
Load this profile into your PP and you will get better results.
Ultra_JRH.ibp
(374 Bytes) Downloaded 240 times
Fabpod
Post by Fabpod »
Many thanks for this. Did ride my bike tis morning on the same loop. Head and tail winds look much more balanced.
I am generally impressed by the technology and the physics behind the product. There is clearly a small learning curve with the Powerpod and ibike.
To better understand the parameters, I would be interested to know what changes you have done to get to this new profile?
Thanks again for your help!
I used the "Analyze/Check Calibration.." feature in Isaac.
Fabpod
Post by Fabpod »
OK thanks for the clarification
Fabpod
Post by Fabpod »
Hi, following our discussion last year, I have used the profile that you sent me back with great success and reliability.
Recently I had to send back my Powerpod to replace the case since it was cracked. Your customer service is great and it was repaired switfly.
I am still using the same profile but my power results now seem to be approximately 15% higher than they used to be (on the same itinary). See attached files.
What would be your recommendation?
Best
iBike_01_21_2017_1449_50_km.ibr
(313.17 KiB) Downloaded 204 times
iBike_01_29_2017_1009_39_km.ibr
(248.07 KiB) Downloaded 266 times
