I'm not sure if many people have one of these in the UK yet, I imported mine as I thought the £349 on Amazon was too steep. Anyway, that's by the by so.....
What road surface setting are any of you using for your typical UK B-road? My local roads are terrible, constantly rumbling along with no real 'smooth' sections. I'm not sure what setting to use to get the most accurate readings.
UK users - what road surface setting do you use?
easy rider
Re: UK users - what road surface setting do you use?
I think rolling resistance is quite a small component of power so I have left it on good asphalt (although it is far from good...)
usedtobefaster
I use the smooth asphalt setting which I believe gives about the right accuracy for UK roads
Paul
Paul
easy rider
Cheers for the info. I'll give those a go.
