Firmware update 6.10
We've just released a new version of PowerPod firmware, 6.10:
• Improved power accuracy and consistency when using PowerPod on hill repeats
• Fixed a bug that causes incorrect power smoothing on ANT+ channel when user sets PowerPod to 0 second smoothing (factory default smoothing is Dynamic Power Smoothing, which is unaffected by this bug fix)
• If PowerPod has already been paired and calibrated to with a speed or speed/cadence sensor, then after a failed re-scan attempt to the same sensor, PowerPod status light now flashes green.
You can get this free firmware update through Isaac software!
Morocco Mole
Re: Firmware update 6.10
Post by Morocco Mole »
This is great, I raised the issue with 0 smoothing on the 5th of Jan but never had any acknowledgement, have just been using dynamic since but prefer to see the raw numbers at times.
