How do i calibrate using a DFPM?
Jonathan
Post by Jonathan »
I've just received my DFPM and would like to use it when calibrating my iBike newton. Can I simply do a standard cal ride, export the data to isaac and save the profile there? Or do I have to setup the profile and choose "best accuracy" and then do the cal-ride? And how do i do this for 2 different profiles (one with high profile wheels and one with low profile wheels)?
The way I think I should do it is:
1. Setup profile #1, choose best accuracy, do cal-ride with DFPM and export to isaac and verify it.
2. Change wheels
3. Setup profile #2, choose best accuracy, do cal-ride with DFPM and export to isaac and verify once again.
Or can it be done in a more simple way?
BR
Jonathan
Return to “Using the Newton with a DFPM”
