sram quarq set up
brumblebikes
sram quarq set up
Post by brumblebikes »
I have the sram quark as a DFPM. How do I check that it is working right? It is saying I am riding at 600+ watts.
Re: sram quarq set up
Please post a ride file and we will take a look.
brumblebikes
Here is a recent file.
iBike_10_14_2012_0841_20_Miles.ibr
(215.67 KiB) Downloaded 561 times
Your Quarq is not calibrated; it's numbers are crazy! (Your Newton looks just fine)
Though I am not familiar with the Quarq, I believe that if you turn the crank backwards three times, that calibrates the Quarq. You might want to check with Quarq.
The Newton is only recording the numbers being sent by the Quarq; so, don't shoot the messenger! :D
dtrousdale
Post by dtrousdale »
Velocomp wrote:... if you turn the crank backwards three times, that calibrates the Quarq.
Last I checked, it was turn back crank 8 - 10 times.
Return to “Using the Newton with a DFPM”
