OS2 for Dash+Power?
ellislo
OS2 for Dash+Power?
Post by ellislo »
John, when can we get OS2 for Dash+Power? Ha....
Re: OS2 for Dash+Power?
We have submitted the update. As soon as Apple posts it...
ellislo
Post by ellislo »
Great!
FelicianoVASA
Post by FelicianoVASA »
Hello once again,
Dear John just a sugestion/question to improve the OS.
The scan for wirelless DFPM sensor can be facultative?
For instance if I use a Powercal strap (wich has HR+Power-estimate :lol: ) I might go to choose only the HR.
Thank you for advance for the attention
FelicianoVASA wrote:Hello once again,
Sorry, I do not understand your question.
FelicianoVASA
How can i miss the DFPM scan?
FelicianoVASA wrote:How can i miss the DFPM scan?
Whenever you do a Scan, the + Power will pick-up any ANT+ sensor. Apparently the PowerCal reports (bogus, in our view) power numbers on the ANT+ power channel.
While there is no way to keep the +Power from detecting the ANT+ PowerCal power signal, there is no reason you have to display the PowerCal signal in the iBike app. In Configure User Screen, just be sure you don't display the DFPM field.
In the ride file, simply ignore the DFPM data.
FelicianoVASA
Tank you Mr. John.
I need to use that system (powercal) because I use them on MTB, for GPS navigation (and lots of dirt and mud), and last day i want to do a test field to calibrate the powercal and see the diferences.
By the way I am very pleased so far with the Idash. Big case but good info, good and accurate readings! Keep the good work!
