Cadence indicator
SdO
Cadence indicator
Post by SdO »
All of a sudden I lost the cadence indicator in my device and am struggling to get it back (not even showing in the screen configurator). Showing calories instead. All other indicators working fine.
Done the following already with no success:
1. Reversed the battery of the cadence sensor;
2. Reset the device.
Any help much appreciated.
SdO
texmurphy
Re: Cadence indicator
Post by texmurphy »
You should check the battery voltage, should be above 2.9V.
Or just replace the battery.
Depending on the sensor, if using a magnet then leaving the crank arm with magnet over sensor can quickly deplete battery.
