Cal Ride Issue
barry6054
Cal Ride Issue
Post by barry6054 »
Hello all! I downloaded the new 5.0 firmware today and had trouble doing my cal ride. Every time I tried(4 times) I would get an error message at the end of the cal ride as well as "see Isaac" on the display screen. My cal ride route was the same I've used before for the first attempt and then a different route on subsequent attempts due to traffic. Also, since I kept getting the error messages The Newton was "stuck" in the Cal ride mode. For the time being I've reset to "better accuracy" in Isaac and Cal is flashing in the center screen with bars beginning on the left and moving to the right. I'm assuming this is correct for the "better accuracy" setting. However, I would like to get the cal ride to work correctly for "best accuracy" setting. I've done cal rides before and have had no issues until now. Any ideas on why I keep getting error messages doing cal rides?? Thanks in advance to all....Barry
Re: Cal Ride Issue
Please contact Tom Gore at technicalsupport@velocomp.com
