ipro mount for FSA K-wing carbon bars
roadrash
Post by roadrash »
Has anyone mounted the ipro to the FSA K-wing carbon bars? Just wondering if the mount will work on these handlebars?
Also, does a new ipro unit come with mounts for both stem and handlebars? I guess I'm wondering if both mounts are included in the box.
Re: ipro mount for FSA K-wing carbon bars
I did get the wireless mount on these bars for my friend. You'll need longer attachment screws than the ones supplied with the mount. The thread pitch is 4-40 and you can pick up ss ones at your local ACE Hardware store.
You buy either the stem or handlebar mount, I recommend the stem mount for your bars. We've put one layer of electrical tape around the bar then using two part epoxy build a base to lay the wireless head on so it sits close to level. Let it harden and away you go. Put a layer of electrical tape on the bottom of the wireless mount so the epoxy doesn't become part of the mount. Don't overdo the tape, it wiggles a lot.
