iBike iPro and wired powertap
thomas_cho
Post by thomas_cho »
Hi all,
Pardon me if this has been asked before, but is there a way to compare the power files between the ibike ipro and powertap?
I have both installed on the same bike, and during the ride when glancing at the two computers, there are times when there are big differences between the two ...
I guess I want to use the powertap to check my ibike settings.
Re: iBike iPro and wired powertap
You can do this.
Download both files on to your computer. Open the iBike software and open your iBike file.
Then, go to File/Merge Signals from another Ride File. This will add your PT information to the ride file. Then, you can use the Power Meter Comparison feature.
thomas_cho
Thanks for the quick reply, that should have been obvious to me ... doh!
Followed your advice, but the Power Comparison feature is greyed out ...
Ah...you need to upgrade your iBike to an iAero version in order to use the PMC feature
