All,
I continually find that my iBike does not hold date and time settings. I have to update it prior to each use - otherwise it defaults back to July of 2007.
What's the trick to have the date/time set and then persist correctly?
iBike Date/Time does not stick
travispape
- Site Admin
Re: iBike Date/Time does not stick
Sounds odd. Are you regularly removing the battery from the unit? Is the date & time set correctly on your computer?
David.C.Anderson
No - I have not been removing the battery.
I have the time set correctly on my PC, and have used several set options for date/time from within the iBike 2 for Windows Software; one under Device > Set Date and Time and some other place that I cannot seem to recall.
In fact, I just checked the unit again (while attached to my PC). I reset the date/time this morning before my ride. I go into the setup menu (Up Arrow for two seconds), and then scroll to the year, month/day, and clock and they are all back to 2007 / 07-12 / 11:17.
I agree that this is strange, but I do not seem to be able to come up with a reasonable explanation.
I just set it again (through the software) and verified that the change is reflected on the iBike (at least for now).
David.C.Anderson
After submitting the previous post, I removed the iBike from my PC connection. I just reconnected and examined the date/time - back to July of 2007.
Is it possible that an attempt to communicate wirelessly could reset the date/time. The only thing that seems consistent here is that after connecting to my PC and the unit powers up - I receive the message stating that wireless failed.
Any other ideas?
Any other ideas?
travispape
- Site Admin
What's your battery voltage reading in the setup pages?
David.C.Anderson
travispape
- Site Admin
That's getting low. Did it keep the time when the battery was fresher?David.C.Anderson wrote:262
David.C.Anderson
I do not recall the behavior being any different.
You say that the battery is getting low.....
I have a total riding time on this battery that is only about 3.5 hours (on the trainer in trainer mode with avg sessions of around 45 minutes). How long should I expect to be able to ride on a single battery? Do people carry extra batteries and switch them mid-ride?
- leonsrocketcar
I was getting about 8rs on my wired unit and now almost double if not more on the wireless.
