Tacx flow
- Steve_Davidson
Re: Tacx flow
You won't be able to match a profile to a Tacx flow because it has literally hundreds of different resistance curves based on the settings you chose. FWIW I had one and found the power numbers to be wildly inaccurate and inconsistent compared to SRM data as have several club mates. Only way to do a curve would be to take one resistance setting and get someone with a DFPM to try and develop a curve for you using the tyre / pressure you would normally use. You could do the same just using the Tacx flow with the computer disconnected altogether (I found this the best way to use it with the SRM and just changed gears to change resistance).feltf1 wrote:I have a tacx flow and none of the profiles match it in my ibike for windows
Steve
