send POWERHOUSE TRAINER ride to STRAVA
chayipov
Post by chayipov »
when I send my islim ride (on trainer) to strava it shows there only 0.6 miles ride instead of 10, did anybody have the same issue?
Re: send POWERHOUSE TRAINER ride to STRAVA
I believe Strava requires GPS information. If you're on an indoor trainer GPS remains fixed, which may be the problem.
Strava does not require GPS data as you can declare the ride a "trainer" ride.
It may be that GPS data was recorded but since you were on a trainer it's just the bouncing around because of a poor GPS signal inside. Try shutting off the GPS data on your next trainer ride, that may solve it.
