Newbie - How to end workout
Just bought the ibike newton. When your workout is complete, how do you indicate that the workout is over? What button do you press? I don't want to not save the data from a ride, so I want to press the right button.
Re: Newbie - How to end workout
There is no need to press any button. Newton stops recording when you stop. If you're concerned about accumulating time as you ride around or move the bike around then press and hold the center button and that will reset the ride stats to zero. Of course the ride you completed is still in memory.
The other thing you can do is to hit the left button to get to the battery screen. Then press and hold the center button until the screen shows OFF. Let go and the unit will shut off.
Note that you never lose any ride unless you purposely go to the clear memory screen. There's no such thing as accidentally losing a ride. You might accidentally reset to zero and start a new ride, but the old ride is always there.
