Interpreting The Data
Now that I have a calibration ride, how do I interpret it? Do I need to perform a wind analysis? What about checking the calibration? In the Analyze Wind graph, is a negative wind (the green bar, I think) ever valid? I'd attach an example, but I don't have access to one right now.
Re: Interpreting The Data
Now that you have done the calibration ride, I suggest taking a short 2-4mi out and back ride,(NOT A CAL RIDE) no drafting, solo, same road. Take that ride file, load it to the Isaac software, and go to ANALYZE->CHECK CALIBRATION... below the "change meter" you will see "send profile to iBike"... click on this, and you should be dialed in.
