New tilt setting
philatlondon
New tilt setting
I was wondering whether I would need to redo the coast downs etc if the tilt has moved slightly. Or can I just do the tilt and everything else will work itself out, all other things being equal? Also, I've lost a couple of kilos since I did my coast downs, so do I need to do another set, or can I just change the weight in the iBike unit?
travispape
- Site Admin
Re: New tilt setting
If the tilt only changed slightly, then that is no problem. Just redo your tilt cal before your ride. If you moved your mount to a different position on your bars or stem, then that would be a reason to redo your coast-downs.philatlondon wrote:I was wondering whether I would need to redo the coast downs etc if the tilt has moved slightly. Or can I just do the tilt and everything else will work itself out, all other things being equal? Also, I've lost a couple of kilos since I did my coast downs, so do I need to do another set, or can I just change the weight in the iBike unit?
And no problem with the weight change either--just enter your new weight in the setup.
Travis
