iSport speed problem
gentlemannosh
Post by gentlemannosh »
Hi, I've just received my new iSport (VERY HAPPY!!!)
However the speed does not work (Less happy). Is there any way to test or are there any likely causes? Even if I rub the magnet back and forth across the sensor, I still get no speed reading with the computer mounted on the bracket.
The computer seems to work otherwise, I can work through the menu and input the settings as required.
Help would be very much appreciated!
Glenn.
Re: iSport speed problem
Please email Aaron Timmer at atimmer@velocomp.com for assistance.
gentlemannosh
Things break, and things are faulty, no matter how good your quality control is.
What isn't chance though is the customer service that I received from Velocomp! Absolutely first rate!
Thanks a million for solving my problem so quickly, I thought that it would take a few days to process, but I barely had time to even have that thought before the replacement bracket turned up at my front door.
And I'm in Australia!
Thank you Aaron,
Glenn.
