Updating data eg weight, tyre size do you need to recal
canberra
Post by canberra »
Hi all
Just wondering if I update weight & tyre size do I need to do a cal rude again ?
And if so do I need to do a complete hard reset ?
Cheers Pete
Cheers
Pete
Canberra Australia
KenS
Re: Updating data eg weight, tyre size do you need to recal
Post by KenS »
Should not be necessary. The main purpose of the ca lride is to set your Wind Scaling Factor (WSF) and Tilt. So unless you change the positioning of the Newton or significantly change the airflow to the wind port a cal ride isn't necessary.
You don't have to do a hard reset even if you redo the cal ride
-- Ken
bobbyperry
Post by bobbyperry »
i update all the time. bodyweight change with ride gear/backpack. change on edit profile section on isaac and send to unit then hit accept
