Uninstall/install firmware
still-chasing
How do you uninstall and install back the firmware in iPro? Thanks
Re: Uninstall/install firmware
You can UPDATE the firmware in an iPro via the iBike software under the "HELP" tab. What seems to be the issue; that you would want to un-install the firmware?
still-chasing
I'm getting an error 6004 when loading the trainer unlock key. Tried flipping the batteries backwards too.
- lorduintah
You might want to double check that you sent in the correct serial number.
