Bad Cal Ride in Mountain Bike
eduardorcosta
Post by eduardorcosta »
Hi everyone, I'm new in the world of power and a newbie in iBike.
I just received my isport and did the calibrations required. After this tried to do a cal ride. But it failed 5 times.
I think i did everything right, but can someone point me some directions ?
Thank you
eduardorcosta
Re: Bad Cal Ride in Mountain Bike
I was able to do the cal ride, after a few instructions from John Haman (Thanks John). After you calibrate everything properly, just lock the suspension (yes just this) and then everything work fine.
The reason I suspect from this is that the tilt calibration and my position riding with the suspension not lock are very different, then it can do the math required.
Just this.
Hope this helps anyone.
Morocco Mole
Post by Morocco Mole »
eduardorcosta wrote:I was able to do the cal ride, after a few instructions from John Haman (Thanks John). After you calibrate everything properly, just lock the suspension (yes just this) and then everything work fine.
Just this.
I am curious what CRR, CDA, Tilt you ended up with in your profile?
eduardorcosta
I ended with this values:
cst aero 1_2366 (i think that is 1,2366)
cst fric 22_92 (I think that is 22,92)
The others I can't view right now, since I'm in another city, but when arrive at home I try to find the others
Morocco Mole
eduardorcosta wrote:Hi,
Yeah, that's fine, when you get to a computer I'm actually interested in the CRR, CDA values with you will find in the profile. Thanks
eduardorcosta
Hi I try to acquire the data you asked, but I thing the only way is by computer right ? Mine is the Isport, so I think I can't view this data.
Anyway, if is a way please point me to it.
And finally, today I was riding and after a long pause (a tire repair) the watts where to low, is there any issue with a pause in the ride that cause a discrepancy in the wattage ?
eduardorcosta
Hi I just upgrade to ipro, and was able to pick up the data: CdA: 0,368 m^2; Crr: 0,0055
Morocco Mole
Hey, thanks. CdA is pretty much where I expected for an agressive MTB position, I'm surprised the Crr is so low, was this done on Tarmac or Dirt\Gravel?
GWPOS
Post by GWPOS »
It sounds like he used the default setting for crr. I started using around .130 when you suggested it once a while ago(I think it was you??). Since then I have adjusted it down to .110 and I think I am still a little high. I have a Cannondale Flash Carbon 29er1 which sits me more straight up so I use a cda of .400. This to may be a tiny bit high but when you are climbing and doing intervals being off al= little bit does not matter so much if at all. Eventually I will go and do another cal ride and some coast downs to confirm my numbers, but been doing to much training and have not had the time.
eduardorcosta
I was using just the default Crr. Now after some tweks I endeed with a value of .088 ( I ride with continental speed king in back tire). I think the right value is about .130 but it ends a negative number in my ibike don't know why.
Thank you
Your Crr estimate is 10 times too high!!! A dirt road has a Crr of about 0.013
GWPOS
Post by GWPOS »
You are right Velocomp, I actually have .0110 for my crr. I made a typo. This number came about after many races and training rides. I still have to tweak my profile some because my watts are still 10-15 watts to high on 20 minutes hill climbs and training rides.
eduardorcosta
Ok Now I understand some data, but not others...
Crr of a dirty road (off road) 0,013 correct ? ( I pick the 0,130 from the startup wizard, rough asphalt)
Crr default is 0,0055
But when I put the 0,0130 in the edit profile and send it to Ibike it display a negative value -0,0093 (is this a bug ?) How can I report this ?
