setting rider height
Something goofy happended to one of my bikes's profiles and among other things it now says that I have to provide rider height. As luck woul have it, there is no place to edit or enter rider height in the edit profile pulldown. Any luck with this anyone? Thanks. Glenn
Re: setting rider height
The only place that you'll need to enter height is in the Fast Start screen. This is used for purposes of calculating your estimated aero.
An easier way to get going would be to hook the ibike up to your computer and resend that particular profile to the iBike.
If you are using an iSport and it's asking for height again, this is probably because you changed the battery, your height and weight setting should still be in there. The only thing you need to update when changing a battery is the time and date.
