I just started using my iSport GT. The data displays in real-time on the Garmin, and I am able to upload the data into Garminconnect and Training Center. However, when I upload the data into Cyclops' Power Agent software, I get the following error "One or more rides were recorded using a variable sample rate. Peak Power, Normalized Power, TSS, and IF cannot be calculated with a variable recording rate"
Has anyone else tried to import the .tcx which contains the power data file from their Garmin to Power Agent?
The iSport is using the original factory configuration and samples every second.
iSport w/Cyclops Power Agent
Re: iSport w/Cyclops Power Agent
Try changing the recording rate on the Garmin from Smart Recording to One Second Recording.
Thanks! It worked perfectly.
