iAero Compatibility
biker2000on
iAero Compatibility
I recently purchased an iAero from ebay and want the stem mount though it came with the handlebar mount, so I'll switch it out with velocomp. I was wondering if the iAero is compatible with the wired speed mount and it just disables some of its more advanced functions, during the transition period.
Re: iAero Compatibility
Yes, you can use your iAero with a wired mount. If the mount has a cadence sensor then you'll get CdA functions; otherwise, your on-screen CdA function won't work.
