Output CdA data for analysis?
djaustin
Post by djaustin »
John,
when I use my DFPM to estimate CdA, can I output the raw data from the plots? I run multiple laps as replicates and would like to estimate some statistics based on GPS position around the course. Is this possible?
Otherwise I guess I can code the raw calculation by importing the CSV file to R/SAS and running a the ISAAC algorithm there instead. Has this been done before? I assume merging Garmin laps will help me here for any analysis?
Re: Output CdA data for analysis?
I don't think we have any way to output raw CdA data.
One thing you can do is put lap markers in your file, then get CdA stats for each lap. This is how I do equipment/position comparisons.
