One PowerPod, Two Computers
lsnadon
Post by lsnadon »
Can you load Isaac on two computers and use the same PP on each one. For example - I ride to work every morning and download rides..... during a break or any other free time, I look at the data. Ditto when I go home, download rides and check out the data...
Not saying I am that anal that I have to check the data every single time I ride, but I just want the data available to me at two locations, on different systems...
Re: One PowerPod, Two Computers
Yes, there is no problem with that. Just make sure you don't have Isaac erase your ride file after downloading it!
meste
Post by meste »
Is it possible to copy the device profiles from one computer to another. On the new one I see only untitled 1 untitled 2 or something similar and not the names I have created.
EDIT: found it myself :-)
meste
Speedyg
Post by Speedyg »
So what was your solution?? I still find this counter-intuitive.
meste
Post by meste »
there is the export option somewhere there. than import on the new computer
Down your ride files into both computers.
After downloading them you can extract the profiles from the ride files. You can name the profiles as you wish.
