HELP: new error started this last wek
ronpei
Post by ronpei »
I have encountered a new error see attachment\
error 1077 occurred at property Node (arg3) in MSGT scale x axis.vi->iBike calculate scale and scale Y axes.vi->iBike top-level VI.va possible reason labVIEW; invalid property value.
is there a newer version of Labview needed? I still get readable files etc but this is a new item.
Re: HELP: new error started this last wek
Try opening a different ride file. This sounds like it might be a corrupted file problem.
ronpei
Post by ronpei »
what is weird is if I ignore the error and continue the file corrects itself.... It seems to be a rendering error on the Y axis. When I analyze the route and enter the correct elevation if seems to correct the screen and the error does not seem to return afterwards when I reload it is OK. Seems odd that it just started but in the long run probably not a world altering issue, but a minour inconvenience.
