I've borrowed a DFPM from a buddy and it's working fine on the Newton as well as reviewing the data in Isaac. The question I have is how to control which data is saved in the .csv for exporting to Trainingpeak etc, (DFPM data vs Newton data)? The reason I'm asking is the numbers are different and for the time being, I want to keep the data consistent in TP so as not to throw off CTL that happens because of the lower numbers from the DFPM.
Thanks, Andrew
riding with DFPM and file export
Re: riding with DFPM and file export
Newton power is in the 'Power' column of the CSV
The is another column "DFPM Power" which 3rd party apps probably ignore.
If you are not getting the outcome you want, edit the CSV file to suit your needs
andrewlees
Thanks Pete. That worked.
