message during Copy Profile
wjwlitespeed
When I tried to copy a profile in ISAAC, I get a popup warning that saved profiles must have a unique pair of Aero & Fric values. Why is this? I thought the profile was integral to the ride file and based on the Active Profile during the recording of the ride. The warning says that the profile is attached to the ride data by matching the Aero & Fric values. Please explain.
Re: message during Copy Profile
The Copy command creates a duplicate of the profile you've selected. Isaac allows only 1 profile with the same aero and fric numbers.
Are you trying to copy the profile into your Newton? If so use the "Export" command.
If you are creating another copy of the same profile in Isaac, then change the fric by 0.0001, an insignificant amount, so that the copy will be accepted.
