Analise Dynamic Cda
Analise Dynamic Cda
Post by Russ »
Travis,
I see the Analise Dynamic Cda is gone missing from the Analyze menu. I miss that already!
I use it with my road bike which has Profile Design aero bars (set wide for comfort and control).
On my rides, I switch from bars to hoods or higher at about 14 mph (23 kh actually) and have used that tool to give a tad higher accuracy to my average power and all. I realize it usually is only a couple of watts (pocket change to some :-) but still I really like the feature.
In fact, for that feature, should you see fit to return (or fix, if it is a bug :-) it, I would like to see the ability to peg the change over to air speed as well as road speed. This way I would not be in a mental conflict over going to the bars in a headwind but below 23 kh and could take advantage of sitting up at higher road speed with a tail wind.
I have read that the 14 mph point is regarded as where Cda begins to be significant (something we who have an iBike are also more directly familiar with :-)! That being because we can see that it is really near the 14 mph of relative wind - hooah (it is veteran's day so allow me this exclamation :-) !
texmurphy
Re: Analise Dynamic Cda
Post by texmurphy »
Russ wrote:Travis,
On my rides, I switch from bars to hoods or higher at about 14 mph (23 kh actually) and have used that tool to give a tad higher accuracy to my average power and all. I realize it usually is only a couple of watts (pocket change to some :-) but still I really like the feature...
So I had CdA Analysis in Isaac v1.0.8, but downloaded v1.0.9 and it is now missing.
CdA analysis is available in 1.0.9, under the tools menu.
Analyze Dynamic CdA is a feature that was withdrawn in 1.0.9. It's tricky to explain and we weren't even sure anyone would notice.
We'll think about adding it back in a future release of SW, once we figure out ourselves how to use it... :D
