Profile 2?
Q&A for all things iSport
mds
Profile 2?
Post by mds »
I've used Est CdA to tweak my calibration so that high speed coasts reads nearly 0 watts. I'd like to do the same with Profile 2 for a different aero situation (a windbreaker), but when I switched to Profile 2 and entered the same data, I get different Aero and Fric values. It is as if Profile 2 has its own calibration (wind scaling and riding tilt) independent of Profile 1 and it looks like the Profile 2 numbers are set to some sort of factory default. Is it possible to transfer Profile 1 to Profile 2 on the iSport so that I can start from that known point?
Re: Profile 2?
When you switch profiles a new calibration ride is required to set the correct wind scaling and riding tilt factors for the second profile. The Cal Ride data for the two profiles are completely independent.
Transferring profiles with a computer is not possible with the iSport.
