I've recently bought a new IBike Sport, which I successfully set up and took for a couple of rides, but it now seems to be stuck in setup mode. I've tried holding the up arrow for 2 seconds to exit setup mode, but this just takes it back into setup mode.
Can anyone help?
Pete.
iBike Stuck in Setup Mode
Re: iBike Stuck in Setup Mode
Take the battery out, flip it over for a second and then reinstall it in the normal direction. You shouldn't lose any settings other than the time and date.
Thanks! That seems to have worked.
Do I need to re-calibrate, or should these settings have been saved?
As stated previously, you shouldn't have to anything other than set the time and date and of course ride.
Thanks again for your help. Problem solved!
