Backup and Restore Profiles
GrumpyChops
Post by GrumpyChops »
Context: I have a PowerPod v3, that I've been using for a few years on my gravel bike. During use I've had a few instances where I've needed to do a factory reset of the PowerPod to resolve issues and each time I've had to go through the setup process/ calibration etc.
Question: I have used the Edit Profiles function in Isaac to backup configurations, by selecting 'Extract from device'. What I'd like to know is if the calibration component of the profile is also included in that file, so that when I do a reset, can I restore an extracted profile to my device and it is then ready to go immediately without having to do anything else?
Additionally, is there any way to add a 650b wheel/tire combo to the profile? I'm currently using the 29'er wheel size as the is the only option that allows me to choose a high volume tire. For PowerStroke configuration, it assumes that I have an old style cadence sensor using a magnet - I have a Garmin cadence sensor fastened to my crank arm that does not use a magnet - what is the best way to describe this configuration in the PowerStroke setting?
Many thanks,
Jon
Re: Backup and Restore Profiles
GrumpyChops wrote: Mon Aug 12, 2024 2:41 am Hi,
Many thanks,
Jon
1). Hard reset does NOT affect profile data.
2). Profile data includes results from cal rides. If you copy/paste a profile from Isaac/VA into your unit, all calibration data will be transferred, too
3) Use "above the chain stay" for cadence sensor setting
GrumpyChops
Thanks for the reply.
For item 1. I mean that I've used Isaac to preform the factory reset: Device -> Setup -> Reset profile/ device -> Complete device reset
For item 2, where I have previously exported the profile from the device after doing a calibration ride, then once the device reset is complete (as above), I can simply use Isaac to reload those profiles to the now empty slots and all should be as prior to the reset? If so, that is excellent!
Item 3 - thanks that is clear.
Regards,
Jon
GrumpyChops wrote: Mon Aug 12, 2024 5:50 pm Hi John,
Regards,
Jon
1) Yes, if you've reset the profile then all data is erased
2) Yes, if you have previously stored those profiles in Isaac, then you can reload them into the empty profiles (NOTE: if you reload profiles, the reloaded profiles will overwrite whatever was previously stored in the profile)
GrumpyChops
Thanks again for the reply.
All clear now, I will make sure I have good copies of my exports for the next time I need to do a reset (a rare occurrence).
Regards,
Jon
