Rechargeable battery charger
dtrousdale
Post by dtrousdale »
When I first put the rechargeable battery into the charger, the indicator lights is green. Does it change to another color when the battery is fully charged? Like does it change to yellow or something like that? Or does it just remain green? Is there any way to know how much charge is in the battery?
ldmitruk
Re: Rechargeable battery charger
Post by ldmitruk »
A green light indicates the battery is charged. You should get a low battery message on the iBike unit when the battery needs to be recharged. When you plug the battery into the charger for recharging the light will be red indicating it's charging.
Note that if you only use the unit for an hour or so, your battery might not be discharged enough to actually require a charge. So be sure to keep it connected for hours, then attach the battery to the charger whereupon you should get a red charging light.
Return to “Installation/Usage Instructions and Videos”
