wired cadence instructions
rmbingham
Post by rmbingham »
I just bought a used Gen I ibike Pro with a wired cadence sensor. Does anyone have the instructions I can download to install it? I've got the speed sensor on and working, but thus far no luck with the cadence sensor.
Re: wired cadence instructions
Have you confirmed the position of the CAD/SPD switch in the CAD sensor assuming you have two sensors?
Try switching sensors and see if you get CAD but no SPD. One of the sensors might not be working or there could be a break in the wire.
Passing a magnet over each sensor - you should hear a click as the magnet activates the internal switch. That is another bit of troubleshooting.
Then - there is the chance that the wire is broken internally from the sensor to the mount.
rmbingham
Post by rmbingham »
Thanks for your feedback. I'll try out your suggestions.
Return to “Installation/Usage Instructions and Videos”
