Partial route selection for analysis
texmurphy
Post by texmurphy »
One of the things which Aero seems to be missing is the ability to select a portion of the activity for analysis.
It is possible in Aero to select from the PEAKS chart the max/min for a time period.
In Isaac one could select part of an activity to analyze by dragging the mouse over part of the chart.
(E.g. selecting a climb from the elevation chart). Isaac would give a summary and also PStroke would analyze that selection.
Can I do this in Aero or is that on a To Do list?
Re: Partial route selection for analysis
Hold the "control" button on your keyboard, then click-drag over the area you want to analyze.
markw65
Post by markw65 »
Another way to do this is to add laps by clicking on a graph at the point you want to insert the lap (a yellow vertical line will appear), and then doing a "context click" (right-click, ctrl-click, or two-finger tap on a touch pad, depending on your setup/platform) on the "Laps" tab. A menu with an option to "Insert lap at <distance> (<time>)" will appear.
Once you've added the laps you want, you can zoom in by clicking on a lap, or get a summary by hovering over a lap (similar to hovering over the peaks graph). And you can save them for future reference.
Return to “Velocomp Aero Software for Mac/PC”
