Aeropod and Pitot tube
speedyvelo
Post by speedyvelo »
I just got the two upgrades one for V3 and the other for Aeropod.
Q: is the pitot tube needed or mandatory for aeropod? I do not ride in the rain.
-=terry=-
Re: Aeropod and Pitot tube
Not mandatory. You should get better crosswind readings with pitot tube attached.
syll1914
Post by syll1914 »
what about consistency in a cross wind?
syll1914 wrote: Sun Jul 21, 2019 7:56 am what about consistency in a cross wind?
I don't understand your question.
syll1914
Post by syll1914 »
the numbers in a cross wind I m not sure that are prety ok, also the power because of this is not so accurate
speedyvelo
Using the Garmin Vector 3, the numbers (watts) in a cross wind are basically the same as with the AP. Except for live CdA I do not have too much use of the Garmin, I just use the AP as my main power meter.
-=terry=-
syll1914
Post by syll1914 »
i m using aeropod like powermeter
syll1914
Post by syll1914 »
what s the differnce between new powerpod and aeropod using like a powermeter?
syll1914 wrote: Sun Aug 11, 2019 3:58 pm what s the differnce between new powerpod and aeropod using like a powermeter?
PowerPod V3 does not come with a pitot tube. AeroPod+ has pitot tube and powerstroke and GPS Tracker. As a power meter both function the same way.
