Sent an email to K-edge and waiting for a reply.
I’ve bought a K-edge bolt combo mount but when installing PowerPod I’ve became aware that when it is leveled, the Bolt points slightly downwards, which is an odd position to read from it.
Can someone tell me if Is there any way to maintain the PowerPod leveled and rise (incline), the top of the Bolt slightly towards me, with some kind of insert in the bolt mount perhaps?
Cheers
I-edge combo Bolt mount
Re: I-edge combo Bolt mount
PP instructions say you should rotate the device skywards, until it reaches the stopped position, then tighten the mount.
If you want to point your mount slightly up, try rotating the PP DOWNWARDS, until it reaches the stop, then tighten the mount. This may do the trick.
I wish, but K-edge mount doesn’t allow PowerPod to move, not even a millimeter.Velocomp wrote: ↑Sat Jun 09, 2018 10:13 am PP instructions say you should rotate the device skywards, until it reaches the stopped position, then tighten the mount.
