Mounting angle change - needs new OB profile
Postby Bugsbunny » Tue Nov 14, 2017 10:51 pm
Hi John
I use an out-front mount for the PP with the Garmin unit on top and PP beneath. I've angled the Garmin so that it not horizontal but slightly angled to face me by say 10 degrees. If I now "flatten" out that angle, so that the Garmin/PP/out-front mount is perfectly horizontal, does that necessitate a new O&B profile? Or what is the recommendation?
Bugsbunny
Re: Mounting angle change - needs new OB profile
Postby Velocomp » Wed Nov 15, 2017 7:11 am
I would do a ride with the mount in the new position. It will take 8 minutes for PP to adjust then it will be OK.
After the ride look at your wind readings. If they appear normal then there will be no need to do a new O&B.
Return to PowerPod General Questions
Who is online
