Hi, the PowerPod shows very low power (60-80 watts) on flats and downhill even though I'm pedaling fairly hard. I'm not in a tuck position which I know can affect the power reading. I've seen this before and it went away but it seems to do this consistently in the past weeks. I'm using an O&B calibration profile done some time ago and didn't recalibrate or change move the PowerPod. Any help would be appreciated. I've attached 2 recent ride files.
very low power on flat and downhill
- iBike_10_28_2017_0837_19_Miles_HiDef.ibr
- (606.26 KiB) Downloaded 179 times
- iBike_10_31_2017_1008_11_Miles_HiDef.ibr
- (365.11 KiB) Downloaded 196 times
Re: very low power on flat and downhill
Actually, your ride files show that you are using a "default" profile, not an O&B profile. This is the cause of your low watts.
Please use the Device/Setup Device feature in Isaac to enter your weight, height, etc. On the final screen, select "Best Accuracy", then do an O&B ride.
After the O&B ride please do another ride, and post that ride file.
Please see calibration and post calibration ride files. Now the power readings seem too high...
- iBike_11_02_2017_1037_11_Miles_HiDef.ibr
- (360.37 KiB) Downloaded 183 times
- iBike_11_01_2017_2219_2_Miles_CalRide.ibr
- (84.6 KiB) Downloaded 178 times
Hi John, could you take a look?
Your seems a bit high--or, you rode in some head winds. I can't tell which is the case
Please do one more O&B, then post it plus a ride.
hi John,
Please see my new cal and post cal ride files.
- iBike_11_16_2017_1608_8_Miles_HiDef.ibr
- (269.06 KiB) Downloaded 182 times
- iBike_11_16_2017_1556_4_Miles_CalRide.ibr
- (112.2 KiB) Downloaded 159 times
Was hoping you can look at my calibration ride in the previous post. I also noticed the same problem with very low power on downhill for recent rides. Please see this new ride file too.
Thanks for your help.
Mike
Mike
- iBike_11_23_2017_0610_30_Miles_HiDef.ibr
- (917.09 KiB) Downloaded 187 times
I don't see any obvious problems with your ride. Your PowerPod is well calibrated.
You are descending a pretty steep hill--6.6% downhill. You do some pedaling at the 8 mile downhill but your slope is so steep that it's really difficult to add power over and above the favorable effect of gravity.
I think you are OK.
I think you are OK.
