Power Pod Not Transmitting Data
Postby Colnago62 » Sun Oct 29, 2017 11:01 am
My Power Pod is not transmitting data to my head unit, a Wahoo Bolt. It had been working previously on my other bike. It seems to connect to the Duotrap speed/cadence sensor (The light goes solid green) and the head unit (Shows up on the sensor menu) but is not sending actual power data. There is nothing blocking the vent and mph shows up on the head unit when the wheel is spinning while the bike is stationary. The PP will sporadically send information for a few seconds, but then the screen goes blank. I have replaced the Duotrap with new unit, so the battery is fresh.
Colnago62
Re: Power Pod Not Transmitting Data
Postby Velocomp » Sun Oct 29, 2017 11:14 am
Are you using the same Wahoo Bolt and PowerPod on your other bike? If so, does your other bike still function normally?
What sensors are you using on your other bike?
Postby Colnago62 » Mon Oct 30, 2017 8:46 pm
One Bike has a Duotrap and the other a Duotrap S cadence/speed sensor. I use the same head unit with both bikes. I tried the Power Pod on both bikes and with the same outcome, no power data showing. I have used the Wahoo Bolt on one bike since July and on the other for one ride before having this problem.
Colnago62
Postby Colnago62 » Fri Nov 03, 2017 8:09 pm
Should I just send the unit in for warranty?
Colnago62
Postby Velocomp » Fri Nov 03, 2017 8:19 pm
Please post .ibr ride files from each bike
Postby Colnago62 » Thu Nov 09, 2017 4:24 am
Not sure where those files are or even how to find them.
I replaced the Bolt with a new one. I was on a Wahoo Forum and heard some people stating that they were having issues with their Bolts after an IPhone firmware update. I followed the instructions and tried reconnecting the whole system Ando started receiving power data. It has only worked on one ride, so not sure if that was the cure or not.
Colnago62
Postby Velocomp » Thu Nov 09, 2017 9:13 am
If you continue to have problems please email technicalsupport@velocomp.com
Return to PowerPod General Questions
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
