GARMIN CADENCE SENSOR ON LEFT CRANK ARM?
When using the POWERHOUSE App and setting the position of the cadence device, it seems to only allow cadence sensor to be above or below the left chain stay. Is it possible to set it for positioning on the left crank arm, as is the required position for my garmin cadence sensor. I would be very appreciative if you could assist me.
Re: GARMIN CADENCE SENSOR ON LEFT CRANK ARM?
I was told to select above the crank arm.
Regards
Regards
Many thanks for your reply. I understand that you mean to custom position the X point above the pedal crank arm at 90 deg.
