Hi
I have searched a couple of the sections for this but can't see it - does Newton Tracker work for the Powerpod as well? I suspect it does as it's a merge within Isaac and the GPS tracking is done via the smartphone rather than the device a la Garmin but wanted to make sure before I shell out the money.
Cheers
Ady Short
Newton Tracker
Re: Newton Tracker
Actually, this is an interesting question!
Most likely you're using a Garmin or other GPS bike computer. If so then you can merge your Garmin .gpx files into your PowerPod .ibr files; no smartphone is required.
We haven't enabled the Newton Tracker feature in PowerPod, because NT is redundant with the GPS from your bike computer.
If this is important to you please send us an email at jhamann@velocomp.com and we will see if we can help.
