Four "Cal Wind" questions
Sykkel
Post by Sykkel »
Questions:
- The “cal wind” number is dimensionless in the Newton display. If the “cal wind” shows +2.1, is that the same as a +2.1 km/h "offset"?...so when riding on a wind free day I will see a (false) +2.1 km/h headwind?
- If the cal wind shows -4.0, but I don’t do a “cal wind” before a ride, how much error will this cause the wind measurement in percent (%)?
- When is it recommended to do another “cal wind”?...when when the number is above 0.1 or 1.0 or 10.0 or 100.0 ?
- Is the “cal wind” temperature depended? If so, at what temperature difference is it recommended to do another “cal wind”?
Background:
I have always seen +/- 2-5 “cal wind” number after a ride when I do “cal wind” before a ride. Then I found that the Newton needs some time to cool down to outside temperature, so I started to do my cal wind after a few km's, but still saw "large" cal wind offset numbers after a ride. Then I started to do the cal wind after a ride, and found this a bit better, but then I saw “large” offset numbers before the next ride a few days later.
It's winter in my country. I store my Newton in the refrigerator a few hour before a ride, because the Newton needs 20-40 minutes to cool down to 0* Celsius from 24*C indoor temperature. Some days ago I did a test and did my "cal wind" outdoor in my garage (wind free) short after a long ride at around 0*C. After 10 minutes it still showed 0.0. I did a 10km ride, and it still showed 0.0-0.1. The next day I saw a +3 "cal wind" offset before the ride. It was -4*C outside. The Newton comes from the +5*C refrigerator environment. I ride for a few km's, stop and see the cal wind now is 0.0...perfect. I ride for 30km`s and then see the cal wind is around -3.6? I reset the cal wind to 0.0, ride another 10km's and now see a 0.0-0.2 cal wind number. I get inside and download the ride files. Inside it's 24* Celsius. After 20minutes the cal wind is +7.2-8.4.......
Re: Four "Cal Wind" questions
The cal wind number is a "pressure" value.
So, cool your unit down to the ambient temperature and do a cal wind offset. Don't bother doing another one until there is a significant change in the seasonal temperature. Don't worry about the changes throughout the ride. Newton handles this automatically. And even if you see a +3 or -3 at the end of the ride, Newton has taken the temp change into account.
The only time I do another wind cal is when it is consistently 10°C higher or lower. Then I will do another offset and leave it alone. So for me luckily that means I do a wind cal in May and don't do another one until almost November.
Don't chase the numbers.
Sykkel
Post by Sykkel »
racerfern wrote:The cal wind number is a "pressure" value.
Thanks for the feedback.
"Don't chase the numbers" Isn't this just what we do?....chasing the (wattage) numbers while riding, or else we don't need the Ibike Newton :D
I really miss the practical information in the Ibike manuals, like "the cal wind number is in pascal, not km/h", "Do only another wind cal if above 3.0", "Ibike take care of wind offset changes while riding", "Do another cal if temp 10*c or more"....
As long as users don't know what -7.4 in the cal wind window is and the consequences of large offset numbers, users will chase the optimal settings (not the numbers).
