PowerPod set up/ config
Postby .:Tim:. » Tue Dec 22, 2015 8:10 pm
I just unwrapped my powerpod LE, collected a couple of training rides, and am poking around at Isaac to make sure I have it configured/set up right.
a few quick questions:
1.) is the USB port on the back 100% waterproof? since it is bare/exposed, I'm a cautious about exposing it to light rain
2.) does the mounting angle play a major role in accuracy? I found it hard to tell if the bracket is level on the handlebars since the bracket grips very tightly and everything is at funny angles (e.g. headtube @ 73 degrees, stem at -7degrees, et c) I read the troubleshooting info about making sure the powerpod is set all the way forward on the bracket against the stop, et c.
I have routinely ridden with a DFPM for the past year (stages), and the numbers yesterday looked pretty spot on with what I am used to from the DFPM- power zones matched my HR zones, et c.
Today, I set out to Experiment with the powerpod and my bike with the DFPM, to see just how "out of balance" my pedaling may be- I'm aware I have asymmetric muscle development, and was curious how far off the "left leg x 2" numbers were. I attached a second mount to the other bike, conducted a cal ride, and a 2 hr ride, recording the DFPM numbers on my iphone (Strava). In short, today the numbers from the powerpod were significantly off- ~ 30-50 watts elevated vs the DFPM, and on average, 30-50 watts higher than yesterday. I figured the numbers might come back into cal as the ride went along (e.g. continuous tuning), but I didn't really notice this. All the holiday cookies I had for breakfast were worth a little power boost, but I don't think this makes sense.
Any thoughts on this? is mounting angle a potential issue? I made sure it isn't obstructed by any cables/housing...
.:Tim:.
Re: PowerPod set up/ config
Postby eschlange » Mon Mar 07, 2016 11:00 pm
Did you ever hear back about weather the USB port is waterproof? Inquiring minds want to know!
eschlange
Postby Velocomp » Tue Mar 08, 2016 7:32 am
We are spending a fortune on the USB port...because it is indeed waterproof! That said, blow it dry after riding, and if it gets muddy, clean it out!
Return to General Discussion
Who is online
